I did the updates of my templates and now my boot options have changed. I’m not sure which selection to make the default. Can anyone help?
The default setting should work fine. Only if it doesn’t you try the alternative ones.
If you only updated the templates, your boot order shouldn’t change. This might indicate a compromise. Such change typically occurs if dom0 has been updated.
