Mullvad on qubes SAFELY?
im fairly new beginer and want to use qubes i have found everything to work how i want besides vpns if tried diffrent method they may have worked but then the dns breaks or somthing else small because the guides are just made by randoms with random scripts to hold back my whole online identity.
pls help me finding a good actual understandable guide on how to make a leak proof setup for mullvad vpn with killswitch and maximum protection without having to rely on things u dont understand
Solene highlighted a few and presumably filtered out some of the lower quality guides. So you may save some time by looking there:
For a “fairly new beginner” probably the easiest way is to install @unman’s mullvad-vpn package, see https://qubes.3isec.org/tasks.html . If you go through the repo setup once, you then have access to all the other goodies (like pre-configured cacher, mirage-firewall, alternative Tor gateway…).
Note/disclaimer: It’s not 100% native QubesOS solution and you have to trust @unman , which you do at your own discretion, and I cannot make any recommendation.
