layout:
'hcl'
type:
'Desktop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Micro-Star International Co., Ltd.
model: |
MS-7D43
bios: |
1.90
cpu: |
12th Gen Intel(R) Core(TM) i7-12700
cpu-short: |
i7-12700 Alder Lake
chipset: |
Intel Corporation 12th Gen Core Processor Host Bridge/DRAM Registers [8086:4668] (rev 02)
chipset-short: |
B660
gpu: |
Intel Corporation AlderLake-S GT1 [8086:4680] (rev 0c) (prog-if 00 [VGA controller])
Advanced Micro Devices, Inc. [AMD/ATI] Navi 24 [Radeon RX 6400/6500 XT/6500M] [1002:743f] (rev c1) (prog-if 00 [VGA controller])
gpu-short: |
Integrated graphics (Intel UHD 770)
network: |
Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
memory: |
65319
scsi: |
usb: |
1
certified:
'no'
versions:
- works:
'yes'
qubes: |
R4.2.0
xen: |
4.17.2
kernel: |
6.1.62-1
remark: |
had to fix UEFI after install
credit: |
Tomas Vondra
link: |
FIXLINK
Remarks
This is an update for the HCL report from about a year ago. I reinstalled the workstation to Qubes 4.2, and this time it worked smoother than with 4.1 - no need to mess with the GPU to make the installer work, no visual artifacts, etc.
I still had to do the UEFI magic, though - after the installer reboots, BIOS did not recognize the boot option and goes directly to setup. I have very little idea how UEFI works (and no ambition to improve this knowledge), so I had to try a couple things. I don’t remember what exactly I did a year ago, but I think the instructions from the docs mostly worked, except that it seems to be for an older version and the files are a bit different (in particular, the file to copy to BOOTX64.efi is grubx64.efi and not xen.efi, IIRC).
I have only spent a couple hours on the reinstalled system, but everything seems to work like a charm - video, audio, network, … I haven’t seen any issues, and I think it may actually works better (e.g. the VMs seem to shutdown much faster, without the strange delays).
So far the UEFI issue was the only thing I had to deal with. Not a big deal, but would be good to have the instructions updated to match current version.
