I’m trying to install qubes R4.2.4 on a Dell Latitude E5540. I checked the requirements and HCL so I think it should work on my laptop but I’m stuck on the anaconda language setup page with the mouse and screen frozen(tab doesn’t work).
This CPU is supported.
Try to switch to the console TTY in the Qubes OS installer using Ctrl+Alt+F2. You can switch back to the installer GUI using Ctrl+Alt+F6.
Did you verify that your installation media is not corrupted?
The default installer boot option “Test media and install Qubes OS” should check it. Did you run it? Was the test successful?
The test is needed to make sure that your installation media is not corrupted. Corrupted installation media could lead to random problems with your installation or installed Qubes OS that will be hard to debug.
Verify that your installation media is not corrupted so we could rule out problems caused by the corruption.
No. After the check is successfully completed, my mouse and screen froze on anaconda installer. Ctrl+Alt+F2 didn’t work. I restarted the laptop and tried install without check option which worked.
