I have created the USB with RUFUS and I boot from the USB correctly but when I get to the select language screen the keyboard and mouse do not work.
Keyboard and mouse work via the same USB (logitech).
Any ideas?
The only time when my keyboard and mouse don’t work is when I intentionaly attack one of my machines with BIOS malware that screws up checksums. Did you try to boot some other distributions? You can write the ISO with balena etcher https://www.balena.io/etcher/ which is simple to use too.
These are guesses but I would ask AS-Rock for their latest BIOS which might include SSD incription (motherboard manufacturers don’t give their best easy). Don’t be shy! Be pushy and demanding!
