Mooltipass hardware wallet with vault
I am trying to use the mooltipass wallet with a Vault appVM.
I have compiled the software: GitHub - mooltipass/moolticute: Mooltipass crossplatform daemon/tools
(currently the appvm based on fedora-41-xfce).
The device is working as it is supposed to when I am attaching it to various qubes in order to write passwords but the main issue is:
when I am running the moolticute software on the Vault AppVM to add new passwords and do configurations although I attach it with sys-usb the program doesn’t recognize it.
Any way on how to troubleshoot ?
The software needs some udev rules that can be found here:
I tried to save them on the /etc/udev/rules.d/ but as it is an AppVM it didn’t save it on restart.
Where should I save them so they survive the restarts? (not sure if that is the actual issue though)
Do it in the template or use bind dirs:
Or try to use /usr/local/etc instead of /etc ?
Great! that seemed to be the issue.
Thanks a lot
