If I adjust the monitor layout on xfce it crashes me back to the login prompt and from there on crashes each time I login back to said prompt. (even past reboots)
On KDE it shortly gave me a paraphrased “couldnt start ksmserver please check your install” and blackscreens, eventually returning to the login prompt too.
Is there a fix? (on kde? my install isn’t xfce anymore) is this a known issue?
Edit: disconnecting a monitor fixes it temporarily, but if I try to apply any changes to monitors/displays it crashes again.
More generally, “unstable” repo is not used on official repositories. It’s mostly for dev/testing purposes locally or for example on openQA. @marmarek@adw maybe it is worth to put a note about it somewhere?
