Create file in dom0 using terminal:
sudo nano /etc/qubes/policy.d/30-monerod.policy
Or using Qubes Policy Editor GUI tool.
Add this inside:
user.monerod * monero-wallet-ws monerod-ws allow
Add this inside:
can you explain followings:
user.monerod : what is this?* : what is this?Other posters in this thread (a few posts above) have different directives in their policy files, including, qubes.ConnectTCP and @default directives. While your example doesnât have those? Why? Whatâs the difference?
user.monerod - service name
* - argument
Itâs described in the qrexec doc:
Policies are defined in lines with the following format:
service-name|* +argument|* source destination action [options]
user.monerod is custom qrexec service that you define, qubes.ConnectTCP is already existing Qubes OS service that you can use like this:
You can read qrexec doc to know about specifics.
Isnât using the existing qubes.ConnectTCP better (âmore secureâ) in this case? It seems like qubes.ConnectTCP limit the capability to sharing just a single tcp port, while defining user.monerod seems like allowing âeverythingâ between the target and source qubes.
Not sure if itâs more secure, but it should be less error-prone during configuration.
Yes.
Okay so I am trying to understand this whole thing. I have been reading the qubes os documentation as well as whonix guide and the protonmail-bridge guide youâve linked. It seems like main the cause for complexity is that I need to setup policy files, startup command files, in dom0 AND the AppVMâs.
The policy file in the dom0 will be stored in /etc/qubes/policy.d/30-user.policy file and will contain, what? â I guess something about qubes.ConnectTCP?
there will be another qubes-rpc stuff inside monerod-ws qube, which will be stored in /rw/usrlocal/etc/qubes-rpc/user.monerod file and will contain some socat command.
there will be a command line command defined in monero-wallet-ws qube inside the /rw/config/rc.local/ file which will contain socat TCP-LISTEN[...] command
another cause for confusion is, the terms âservice nameâ and âpolicyâ. What is âservice nameâ in this context?
Is service-name a systemd service (is it a --user service, or a root account service)? Or do we name stuff like qubes.ConnectTCP as âservicesâ ?
Iâm assuming that you want to use qubes.ConnectTCP instead of custom service.
Then you need to follow the guide for Opening a single TCP port to other network-isolated qube in the firewall doc linked before. You need to follow 1. Simple port binding + 4. Permanent port binding.
In dom0, add the following to /etc/qubes/policy.d/30-user-monerod.policy:
qubes.ConnectTCP +18081 monero-wallet-ws @default allow target=monerod-ws
In monero-wallet-ws run these commands:
cat << 'EOF' | sudo tee /rw/config/monerod-service.socket >/dev/null
[Unit]
Description=monerod-service
[Socket]
ListenStream=127.0.0.1:18081
Accept=true
[Install]
WantedBy=sockets.target
EOF
cat << 'EOF' | sudo tee /rw/config/monerod-service@.service >/dev/null
[Unit]
[Service]
ExecStart=qrexec-client-vm '' qubes.ConnectTCP+18081
StandardInput=socket
StandardOutput=inherit
EOF
cat << 'EOF' | sudo tee -a /rw/config/rc.local >/dev/null
cp -r /rw/config/monerod-service.socket /rw/config/monerod-service@.service /lib/systemd/system/
systemctl daemon-reload
systemctl start monerod-service.socket
EOF
Itâs referring to the Qubes RPC services and Qubes RPC policies, not systemd services:
Thanks for the detailed responses.
However, I already have:
a monerod-ws AppVM in which I run a user-level monerod.service file (using systemctl --user enable --now monerod.service).
monero-wallet-ws AppVM in which I run Feather Wallet.
I want to (I guess) establish a TCP port connection from monero-wallet-ws to the monerod.service qube, so that the Feather Wallet can pull the monero blockchain data from the monerod running in the other qube.
So, I donât understand why I should use the monerod-service files you just give me. Do I have to use the socket config file you give me? Can I not listen in on 127.0.0.1:18081 using the socat stuff that the previous people in previous guides seem to use?
These files are needed to configure the permanent port binding between qubes using qubes.ConnectTCP service as described here:
If you donât want to use qubes.ConnectTCP service and you want to use the custom Qubes RPC user.monerod service instead then you can follow the guide from Whonix doc but using new policy format:
I want to use qubes.ConnectTCP because it sounds like it does what I want (and only what I want): just forward a port between two AppVMs.
So, in this vein, how about using this one?
This one seems to use qubes.ConnectTCP service from (dom0) /etc/qubes-rpc/qubes.ConnectTCP. Further, using this one, I wonât be needing to create (dom0) /etc/qubes-rpc/user.monerod file (saving me from cluttering, and possible mistakes).
Then you can follow the steps in my previous post about qubes.ConnectTCP usage.
Just adding /etc/qubes/policy.d/30-user.policy file in dom0 with qubes.ConnectTCP policy is not enough, you need configure the use of qubes.ConnectTCP service in the monero-wallet-ws to bind the port between qubes.
It is so fucking confusing because I am trying to juggle 4 different guides, and come up with a sane synthesis of them: 1 2 3 4
So, I start on dom0 creating a policy file:
sudoedit /etc/qubes/policy.d/30-user.policy
add the following line into the file:
qubes.ConnectTCP +18081 monero-wallet-ws monerod-ws allow
Now, are you telling me that I need to repeat this 30-user.policy file in the monerod-ws qube, inside /rw/usrlocal/etc/qubes-rpc/user.monerod file? Why the repeat? Isnât this already saying âaight, establish the connection of the port 18081 between the two monero qubesâ ?
My guess is @appartus wanted to say you will need to run the connectTCP command in the whonix qube to make the port binding effective (itâs what the rule allows), Iâm doing it from /rw/config/rc.local in a qube and itâs working fine, dunno if there is a better place to run it.
Something like
qvm-connect-tcp 18081:@default:18081
So yeah, you add this qvm-connect-* command to /rw/config/rc.local file on your monero-wallet-ws.
However, I guess I also need to instruct monerod-ws qube to expose its 18081 port to stdin/stdout using socat or something? Or is monerod-ws qube already ready for the qvm-connect-tcp command coming from the monero-wallet-ws qube?
this will bind the local port 18081 to the target port 18081, if itâs listening on localhost on that port on the remote, then you do not have anything else to do.
Thatâs cool. Now that I have some cursory understanding of what I am doing, let me try these.
When I try to create file 30-user.policy in dom0 I get the following error:
(dom0) $ sudoedit /etc/qubes/policy.d/30-user.policy
sudoedit: /etc/qubes/policy.d/30-user.policy: editing files in a writable directory is not permitted
How do people create the 30-user.policy file in dom0?
EDIT: oh, ${SUDOEDITOR} is undefined in dom0. My bad.
Amazing. It worked. And the only policy file I created is the one on dom0. I really donât know why the previous guides all create mumbo-jumbo of policy files across dom0, monerod, qubes, etc.
Create the 30-user.policy file on dom0. Fill it with this:
Then, go to your monero-wallet-ws qube. On the terminal enter the command:
qvm-connect-tcp 18081:monerod-ws:18081
From then on, your Feather Wallet will be able to connect to a monero node on 127.0.0.1:18081. Thatâs it. No need to add an rpc/policy/socat/etc/etc/ files in monerod-ws nor monero-wallet-ws qubes.
Would it be possible for you to rewrite the guide (or write a new one) with your split monero setup? As you discovered, there are multiple guides that are complicated and not really up to date.
