Qubes Disk Space Monitor
WARNING!
You are running out of disk space.Metadata space for pool vm-pool is running out. Current usage: 95%
varlibqubes is around 10 GiB out of 20 GiB full, vm-pool is roughly 300 GiB out of 700 GiB full. Clearly, there’s still a lot of space remaining.
What does this warning tell me and what should I do? Can I somehow increase the metadata share of the full disk?
VM's won't start - LVM Metadata reached 100% sounds scary — apparently that person couldn’t even delete VMs when the LVM metadata reached 100%.
Thin pool running out of disc space (SSD) sounds unrelated, the disk in that example is actually full.
