Memes about Qubes OS
Qubes leads to infinity …
i am so confused by this, why does zoom capture dom0? and then dom0 seems to be in a windows7 window? what is happening here? ahhh. :slight_smile:
I’m guessing it’s a capture card working as a webcam, correct?
You are right - HDMI to USB on another computer. :innocent:
I think the webcam-companion (not sure it’s called like this) qubes os project can now expose dom0 screen as a webcam.
That is correct
But video recording is slow due to software encoding.
lim( qubes, qubes → ∞)
I tried now with the qubes-video-companion, and under R4.2.3 it shoots Qubes to infinity, too:
Under R4.1.2, screen share works for AppVMs as the sender, but dom0 as the sender just says “Operation canceled by sender”. So far, I have not found out why. It could be a problem of policy or a protection failure.
This meme is true because everything you need to run is requires a good driver.
qubes-vm-create
In loving memory of the old Create new qube senior dialog, I am saddened to announce it passing away. It had served us all well for over a decade. It has survived by its child Create New Qube junior dialog. It may rest in peace.
Both are still working here on R4.2 with the latest dom0 updates.
That is correct. But I executed it last night. The PR is going to be merged after OpenQA test is complete. Then the old dialog will be deleted from r4.3 testing. Here are the details:
Can’t wait to see this memory of past go into archive land
I always had the fear, that the dialogs do not lead to the same result :joy:
Would a Beware Of The Pipeline meme be disallowed here due to community guidelines? If not please send your various Linux Distro suggestions. I’m going to make a x to QubesOS pipeline meme.
@a_lurker_no_more I look forward to seeing it :slight_smile:
If you have to ask, the answer is likely yes. Yes.
