I want this bash script to send notifications when battery reaches 40% and 80%.
#!/bin/bash
# Set the thresholds
LOW_THRESHOLD=40
HIGH_THRESHOLD=80
# set the display and d-bus session address
export DISPLAY=:0
export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
while true; do
# Get the current battery level
BATTERY_LEVEL=$(cat /sys/class/power_supply/BAT0/capacity)
# Get the current charging status
CHARGING_STATUS=$(cat /sys/class/power_supply/BAT0/status)
# Notify to plug in the charger
if [[ $BATTERY_LEVEL -le $LOW_THRESHOLD && $CHARGING_STATUS != "Charging" ]]; then
notify-send "Battery Low" "Battery level is ${BATTERY_LEVEL}%. Plug in AC."
fi
# Notify to unplug the charger
if [[ $BATTERY_LEVEL -ge $HIGH_THRESHOLD && ($CHARGING_STATUS == "Charging" || $CHARGING_STATUS == "Not charging" || $CHARGING_STATUS == "Waiting to discharge") ]]; then
notify-send "Battery High" "Battery level is ${BATTERY_LEVEL}%. Unplug AC."
fi
# Wait 5 minutes before checking again
sleep 300
done
Also I have a service for it
[Unit]
Description=Battery Notification Service
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/local/bin/battery_notification.sh
Environment="DISPLAY=:0"
Environment="DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus"
# this is my username example
User=batteryuser
ProtectSystem=full
ProtectHome=true
NoNewPrivileges=true
[Install]
WantedBy=multi-user.target
And it still gives me an error after running
systemctl status battery-notification.service
in dom0ās terminal:
Jul 09 10:15:33 dom0 battery_notification.sh[7320]: Cannot autolaunch D-Bus without X11 $DISPLAY
Do you know how to fix it? ![]()
