I installed Qubes OS 4.0.4 on my laptop. And I need to randomize mac-address which is visible for external WiFi routers.
This should be done before first internet connection with Qubes.
I read in manual that I have to edit template (“write the settings to a new file in the /etc/NetworkManager/conf.d/ directory inside of template”).
I see fedora-32 template. But it’is impossible to open any directory inside of this Fedora-32 (no “fedora 32: files”, only “fedora 32:terminal”). And it’s impossible to use sudo nano in fedora 32 terminal (“command not found”).
