Hi all. My issue is that when I run aerodump-ng, the results display in a very light gray colored font. I would like to make the color darker and more readable.
I found settings for the terminal window under EDIT/PREFERENCES, but the changes I make don’t get applied after I change them.
Any suggestions would be appreciated. Thank you.
