Looking for a Qubes OS-Compatible Motherboard for 7800X3D – Budget-Friendly Options?
Hi, does anyone recommend a motherboard for the 7800X3D at a reasonable price? My current one isnt compatible with Qubes OS.
Check out the HCL page: Hardware compatibility list (HCL) | Qubes OS
Edit: Was somewhat short, but better to pick yourself. Best motherboard is the one that meets your requirements, example i want 10GB ethernet or I need 2x m.2 slots and so on. But before buying always check reviews online from multiple sources.
