Logi Bolt USB?
Hi !
Anyone use/used Logi Bolt USB to pair 2.4ghz connections with mouse/keyboard ?
Any issues I may encounter with, without installing logitech soft ?
Thank !
Working without issues… Tested on a NitroPC, several Lenovo Laptops and a Dell Lattitude 5540
Thank a lot !
I already ordered it, but can you explain how you connect multiple devices to it without Logitech software?
From what I remember, just plug in (the USB dongle) and the devices will work (if you allowed them / it to dom0).
Okey I will try that.
Thank you
Hi again !
I got my Logi Bolt USB and it asked me “Do you want to allow the following operation” with target dom0 and InputKeyboard ( twice ! ) and InputMouse ( twice ! ) and when I allowed it nothing happened. How do I connect my keyboard to it ?
Do I need some pairing software to be installed in my sys-usb for this to work ?
Why does it asks twice for keyboard and mouse ( I just plugged it in ! )?
By asking “twice” I guess you still have two (different) Keyboards and Mouses connected… (the old one and the new?). I don’t think you need some additional software to get it paired finally, but who knows.
Have you still your old keyborad and mouse ready? Can you test, if it still is working (after allowing them to target dom0)
No, only laptop and nothing else.
Don’t you have it working ?
Not sure what you mean.
But when I allowed the popups ( all 4 of them ! ) nothing happened.
I need to somehow pair the devices with it !
If it’s a Laptop the first popups are the Laptop keyboard and the touchpad (I guess) and the second the Logi Bold stuff. But looks like you need some additional software…strange! It’s working fine here (on my side) without any software. No clue, whats the problem.
