Ok so i shut everything down then re-started up, then opened up a 500MiB .odt all ok, then edited it a little then clicked SAVE AS it all looked good but when i checked the folder it had created another file called; lu57362bcmw.tmp which usually means it went wrong at its o in size so then i tried to open the .odt document yet it wouldnt recover, anyways, when the .odt was open fully and looking good i did the df -h command and got the below if that helps any…
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/dmroot 20G 13G 6.2G 67% /
none 20G 13G 6.2G 67% /usr/lib/modules
devtmpfs 212M 0 212M 0% /dev
tmpfs 1.0G 8.0K 1.0G 1% /dev/shm
tmpfs 89M 816K 88M 1% /run
tmpfs 1.0G 513M 512M 51% /tmp
tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service
/dev/xvdb 12G 731M 12G 7% /rw
/dev/xvda1 200M 0 200M 0% /efi
tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-resolved.service
tmpfs 45M 84K 44M 1% /run/user/1000
tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service
tmpfs 1.0M 0 1.0M 0% /run/credentials/serial-getty@hvc0.service
/dev/dm-0 932G 526G 407G 57% /run/media/user/blahblahblah
I tried the install commands earlier on today in the Template before updating everything yet to no avail
“libreoffice-1:25.8.7.3-3.fc43.x86_64” is already installed”
Nothing to do.
bash-5.3#
