After the great advice here I have decided to grab a w530. I’ll replace the hd with a fast ssd and max out the RAM. And of course get rid of win10 and put qubes on it!
Would someone who has done this be kind enough to recommend some top shelf, quality RAM that would be suitable for this laptop?
Could you elaborate on that second part? What do you mean the laptop isn’t good for all-day use? I’m thinking about getting a Librem 14 but I want to do more research into the quality of their products before spending over $2k on it.
I just mean that the librem without german keyboard layout is not good for my purposes.
@Raphael_Balthazar: ah, ok. But what about, if i’m running a VM that needs rather much RAM and there I have something like 1G intial and 4G max and need more? Will it automaticaly give me more than max?
As far as I know you have to increase the maximum memory in the settings of said Qube. Then it should be able to use more than 4GB but also only if needed.
