Lenovo ThinkStation D30
layout:
  'hcl'
type:
  'tower'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
remap:
  'yes'
brand: |
  LENOVO
model: |
  42235W5
bios: |
  A1KT54AUS
cpu: |
  Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Xeon E5/Core i7 DMI2 [8086:3c00] (rev 07)
chipset-short: |
  FIXME
gpu: |
  NVIDIA Corporation GP107 [GeForce GTX 1050] [10de:1c81] (rev a1) (prog-if 00 [VGA controller])
  Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:66af] (rev c1) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 06)
  Intel Corporation 82574L Gigabit Network Connection
memory: |
  24525
scsi: |
  BD DH12B2SH      Rev: 9L3A
  SanDisk SDSSDA12 Rev: 30RL
usb: |
  4
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.0
  xen: |
    4.8.5-34.fc25
  kernel: |
    5.4.125-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
  1. USB-WIFI → working using TP-link Archer T3U Plus usb adaptor → using RTL99x2BU linux drivers (GitHub - RinCat/RTL88x2BU-Linux-Driver: Realtek RTL88x2BU WiFi USB Driver for Linux · GitHub) → BUT had to remove the line → BUILD_EXCLUSIVE_KERNEL=“^4.9.*” ← from “/usr/src/aufs-4.9+20161219/dkms.conf” to work…actually works amazing…I get >200mbps using this driver (only got ~70mbps on the windows 10 pro crap install I had on this machine previously)
  2. Windows 10 pro HVM up and running…working well, used for my professional and academic digital activity, latest update (FYI de-bloated and disabled all telemetry and Microsoft ‘kosher’ spyware using O&OShutup10)
  3. Still HAVE NOT:
  • installed Nvidia or AMD drivers
  • no Bluetooth
THANK YOU FOR DEVELOPING QUBES!! and supporting the alternate economy and cyber-privacy movement!
Thank you @ark for your HCL report, which is now part of this pull request:
… and will be visible on the website soon!
Great! thanku…
Question - is this a good place and thread to post issues I have (eg- if I decided to install graphics drivers and have problems?)
2 posts were merged into an existing topic: Where to Post Follow-up Issues?
