After a few times using kleopatra notepad in fedora vault to decrypt different messages in same notepad kleopatra keeps crashing- a qubes user had told me try and create the same qube in debian and see if same issue persists with my vault qube. I’m unsure of how to transfer over everything to that successfully.
when torrenting sometimes my vpn connection seems to fail and it gets stuck at 0% downloading or my search function in qbittorrent will stop working. sometimes things work and download other times they just stay at zero. even when i switch to whonix i may be able to search again and find torrenting files but it gets stuck at zero when trying to download files.
an error message i will get at the bottom of the list of torrents or when my mullvad vpn connection seems to run into issues it gives me this error. upon reading the documentation im not sure of how to set this up in qubes correctly. fedora 42 based qube
Jackett: api key error! Right-click this row and select 'Open description page' to open help. Configuration file: '/home/user/.local/share/qBittorrent/nova3/engines/jackett.json' Search: 'everybody loves raymond'
