Kicksecure Qubes Packages
Has anybody tried installing Kicksecure meta packages kicksecure-qubes-cli or kicksecure-qubes-gui?
Is this a way to install security-misc within a VM?
You can’t be anonymous without being secure. Security hardened operating system Kicksecure is the core of Whonix.
As described on;
https://www.whonix.org/?
I don’t think it includes security-misc package by default
Since ‘security-misc’ is only available in the Kicksecure repositories, you would have to use a Kicksecure installation to use it properly:
user@disp1277:~$ apt info security-misc
Package: security-misc
Version: 3:28.6-1
Priority: optional
Section: misc
Maintainer: Patrick Schleizer <adrelanos@whonix.org>
Installed-Size: 403 kB
Depends: python3, libglib2.0-bin, libpam-runtime, sudo, adduser, libcap2-bin, apparmor-profile-dist, helper-scripts, libpam-modules-bin, secure-delete, dmsetup, dconf-gsettings-backend | gsettings-backend
Replaces: anon-gpg-tweaks, swappiness-lowest, tcp-timestamps-disable
Homepage: https://github.com/Whonix/security-misc
Download-Size: 131 kB
APT-Manual-Installed: no
APT-Sources: https://deb.kicksecure.com bullseye/main amd64 Packages
Description: Enhances Miscellaneous Security Settings
 https://github.com/Whonix/security-misc/blob/master/README.md
 https://www.whonix.org/wiki/Security-misc
 Discussion:
 Happening primarily in Whonix forums.
 https://forums.whonix.org/t/kernel-hardening/7296
There are useful instructions on how to distro-morph a cloned Debian Template VM into a Kicksecure Template VM to be found here.
Works pretty well, but of couse, official templates would be nice, too.
distro morphing is exactly the approach I was thinking of using.
