gasull
October 24, 2023, 1:26pm
1
I switched my main TemplVM to Kicksecure and since then I have problems with sdwdate
oathtool
doesn’t give the right OTP anymore since the time is always inaccurate.
some networking apps that require syncing fail, also because of the clock.
Any way to fix this? Should I just use NTP (or maybe ntpsec
) in the ClockVM?
DVM
October 24, 2023, 3:27pm
2
Can you try to run sudo qvm-sync-clock
in dom0 and then sudo systemctl restart sdwdate
in the DispVM?
gasull
October 26, 2023, 1:59am
3
It seems to not be happening right now. I think it’s an intermittent error.
gasull
October 26, 2023, 3:12am
4
Now it’s happening again, even after doing this.
Shouldn’t sdwdate be disable in an offline VM (like the one I use for oathtool
DVM
October 26, 2023, 9:43am
5
For some reason it’s happening to me too randomly.
If the qube is offline then you can disable sdwdate since it can’t reach any domains for its test.
gasull
October 29, 2023, 4:25am
6
I think the problem was this supposedly fixed issue with qubes-sync-time
. I fixed it for me by adding these 2 lines to /etc/rc.local
(so it works for all VMs):
rm -v /var/run/qubes-service/clocksync
service qubes-sync-time restart
I also uninstalled sdwdate
because it requires Tor working on the ClockVM (sys-net) and I’m using chrony
instead (the default in Ubuntu nowadays). Uninstalling sdwdate
triggered uninstalling a few things, so I’m not running a pure Kicksecure installation anymore.
