KGpg autostarts on every Whonix 18 appVM - despite it being off in settings
KGpg was installed via whonix template successfully, but it autoboots on any whonix appVM now! Autostart is turned off in the settings.
How can I prevent it from autostarting on every single Whonix AppVM?
Thank you
It may have installed itself into /etc/xdg/autostart.
It did. used sudo rm to remove it. Thank you!
