Keep menu opened during Screenshot
Hey :slight_smile:
When I try to take a screenshot in dom0, I want the desktop and the small Qubes menu window in the top left to be visible.
But when I press the Print key, that menu window closes immediately, so the screenshot only shows the desktop and the top bar.
Is there a way to keep the menu open while taking the screenshot?
Thanks for any help :slight_smile:
Hi @AIAC and welcome here.
Your question is not related to Qubes OS because the tool comes from Xcfe. Use “Delay before capturing” option:
https://docs.xfce.org/apps/xfce4-screenshooter/usage
Thank u so much!! :white_check_mark:
