Kasm Workspace
I know Kasm only superficially at the moment but i ask me, if i could build something similar to Qubes with Kasm, so with isolated apps and div. Operating systems? Does anyone already know Qubes Os and Kasm?
Greetings
Looks like a dump idea on the first look, but if your convinced, tell me more.
Remote Desktops/Apps streamed via web …somehow defeats the purpose of using QubesOS.
Hello @rumpelstilz, welcome to this forum.
No, I just searched
Me too
Well, in short, like qubes os, no
The reason for this is that they are completely different.
The Qubes OS operating system aims to protect you from being compromised by relying on the principle of isolation.
Kasm, on the other hand, focuses on browser security; it does not provide protection against user interface (UI) manipulation, nor does it shield you from viruses present on the host machine. Kasm is significantly less secure than Qubes OS, as it relies on Docker, which has a much larger codebase than Xen.
Note: This is a cloud-based service. If you stop paying for the hosting, the cumulative cost—should you decide to host it yourself—would eventually equal the price of purchasing a laptop capable of running Qubes OS.
Nevertheless, it may have its uses, depending on your specific threat model. (I am not familiar with this project, so I do not trust them; however, if you have a valid reason to trust them and believe they are sufficiently secure, they might be of some use to you.)
yes, you can self-host kasm. i use it in one of my projects, not with qubes, but yes, it is interesting thing.
Iwill try it together with Proxmox, self-hosted, then i have bove benefits. Yes more Qode then Qubos, but more opportunities for Hardware etc. and easier to handle,. Kasam has isolation, also with disposibal OS or Apps, and i can login up to 5 machines and wih more speed. How secure it is, maybe secure enough for me.
Well, since you find it secure enough for you,
and see it as easier and lighter,
then I think it’s a good fit for you.
I wish you success
Somewhat, but not as you might imagine; most devices meet the requirements of Qubes OS.
Yes, but only via the browser. For instance, if you are using a compromised phone, an attacker could indeed see everything you do;
however, it remains useful if your threat model is limited to specific actions, rather than encompassing everything else.
Additional note:
Take some time to reflect and read further before deciding whether it is safe enough for you; then, choose what you deem appropriate. This extra verification process will help you determine whether it truly meets your expectations.
If you feel that the level of security is insufficient and would like to try the Qubes OS operating system, do not hesitate to ask any questions regarding issues you might encounter.
A second additional point:
Following the initial setup, I believe that in such cases, it becomes your responsibility to hide your IP address, secure your network, and manage updates yourself.
Qubes Air: Generalizing the Qubes Architecture | Qubes OS ?
