Hello, I have created a Kali Linux HVM that the network will not work. I have followed the official Qubes documentation on manually setting up the network by setting the IP, Netmask. Gateway, DNS servers from the Kali Qube settings. The network icon just spins it seems to have a connection while spinning, it stops and says disconnected I have searched the Qubes forum and read several treads.
I am using Qubes 4.2.4 .
Any help is appreciated.
I don’t know if it was resolv.
edit: Sorry, I don’t use standalone ![]()
I had an old standalone with linux mint: No connection with the sys-vpn. I setup with firewall, I get the connection then, i setup with the sys-vpn as NetVm and keep the connection but after reboot, i lost connection again.
I never used Kali. When you are talking about “Kali Linux HVM” you are talking about a Standalone right?
Yes, it is Standalone. Using sys-firewall nor sys-vpn has worked same results…
I read over and even tried the fixes in that post you brought to my attention, it did not resolve my issues. My Kali HVM will connect while the network icon is spinning for approximately 2 ot 3 minutes I can ping , use a browser will connect to a site, then network disconnect.
Thank you for replying.
