When I try to update my whonix machines i have this error:
Release file for tor+https://deb.kicksecure.com/dists/bullseye/InRelease is expired (invalid since 80d 4h 8min).
Updates for this repository will not be applied.
Also my system is consistently changing the date to 2022 and I need to make timedatectl set-time from time to time but the error I am trying to resolve is happening when the date is set to current
Do you have Qubes OS 4.1?
Do you have sys-whonix as dom0 update proxy?
Does your sys-whonix connects to Tor successfully?
Maybe Qubes Template Manager can’t update the templates repository because sys-whonix is not connected to Tor and so you don’t see the new templates.
You can try to use CLI tool, but it should be the same:
qvm-template list
qvm-template install whonix-gateway-17
qvm-template install whonix-workstation-17
It could be hardware issue.
You can try to rule out the issue with the OS by testing this:
boot into BIOS
change time there
power off
power on
enter BIOS without booting in the OS
check the time
If the time will be reset then it’s a hardware issue. Maybe your CMOS battery is dead and you need to replace it.
