When i try to update using Qubes OS Update all updates that are available fail(Updates for debian, fedora, whonix-gateway and whonix-workstation). Does Qubes OS downloads updates threw Tor ignoring direct connection setting that i used when installing Qubes (Tor is blocked in my country and for my use case i dont need anonymity)? Because i see strings like this in logs (Fail to refresh InRelease: tor+https://fasttrack.debian.net/debian bookworm-fasttrack InRelease from tor+https://)
Here are error logs:
For debian:
Updating debian-12-xfce
Refreshing package info
Refreshing packages.
Fail to refresh InRelease: https://deb.debian.org/debian bookworm InRelease from https://deb.debian.org/debian/dists/bookworm/InRelease
Fail to refresh InRelease: https://deb.qubes-os.org/r4.2/vm bookworm InRelease from https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease
Fail to refresh InRelease: https://deb.debian.org/debian-security bookworm-security InRelease from https://deb.debian.org/debian-security/dists/bookworm-security/InRelease
Refreshed.
E:Failed to fetch https://deb.debian.org/debian/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Some index files failed to download. They have been ignored, or old ones used instead.
For fedora 39:
Updating fedora-39-xfce
Install requirements
Error: Failed to download metadata for repo 'fedora': Cannot prepare internal mirrorlist: Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=fedora-39&arch=x86_64 [CONNECT tunnel failed, response 500]
For whonix-gateway:
Updating whonix-gateway-17
Fail to refresh InRelease: tor+https://fasttrack.debian.net/debian bookworm-fasttrack InRelease from tor+https://fasttrack.debian.net/debian/dists/bookworm-fasttrack/InRelease
Fail to refresh InRelease: tor+https://deb.whonix.org bookworm InRelease from tor+https://deb.whonix.org/dists/bookworm/InRelease
Fail to refresh InRelease: tor+https://deb.kicksecure.com bookworm InRelease from tor+https://deb.kicksecure.com/dists/bookworm/InRelease
Fail to refresh InRelease: tor+https://deb.debian.org/debian bookworm InRelease from tor+https://deb.debian.org/debian/dists/bookworm/InRelease
Fail to refresh InRelease: tor+https://deb.debian.org/debian bookworm-updates InRelease from tor+https://deb.debian.org/debian/dists/bookworm-updates/InRelease
Fail to refresh InRelease: tor+https://deb.debian.org/debian-security bookworm-security InRelease from tor+https://deb.debian.org/debian-security/dists/bookworm-security/InRelease
Fail to refresh InRelease: tor+https://deb.debian.org/debian bookworm-backports InRelease from tor+https://deb.debian.org/debian/dists/bookworm-backports/InRelease
Refreshed.
E:Failed to fetch tor+https://deb.debian.org/debian/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch tor+https://deb.debian.org/debian/dists/bookworm-updates/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch tor+https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch tor+https://deb.debian.org/debian/dists/bookworm-backports/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch tor+https://fasttrack.debian.net/debian/dists/bookworm-fasttrack/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch tor+https://deb.kicksecure.com/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch tor+https://deb.whonix.org/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.1 500 Unable to connect Server: tinyproxy/1.11.1 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082], E:Some index files failed to download. They have been ignored, or old ones used instead.
For whonix workstation:
Updating whonix-workstation-17
Refreshed.
