I’m running an external apt-cacher-ng instance to cache packages on my network, however it seems there’s an issue with tinyproxy Upstream option and the HTTPS/// rewrite on apt-cacher-ng.
Flow is as follow
Fedora 38 Template <-> Tinyproxy (On sys-net) <-> Apt-Cacher-NG (On another PC)
Fedora 38 /etc/yum.repos.d/fedora.repo
Adjusted:
metalink=http://HTTPS///mirrors.fedoraproject.org/metalink?repo=fedora-$releasever&arch=$basearch&protocol=http
Tinyproxy /etc/tinyproxy/tinyproxy-updates.conf
Added:
Upstream $apt-cacher-ng-ip:port
However, requests are arriving at apt-cacher-ng as:
1686930988|E|647|$sys-net-ip|HTTPS/mirrors.fedoraproject.org/metalink?repo=fedora-38 [HTTP error, code: 503]
If I try curling directly from sys-net using apt-cacher-ng ip as all_proxy, things work correctly:
all_proxy=$apt-cacher-ng-ip:port curl -v http://HTTPS///mirrors.fedoraproject.org/metalink?repo=fedora-38&arch=x86_64
1686931962|M|Download of fedora/metalink?repo=fedora-38 started
1686931962|M|Download of fedora/metalink?repo=fedora-38 finished
1686931962|I|1162|$sys-net-ip|fedora/metalink?repo=fedora-38
1686931962|O|523|$sys-net-ip|fedora/metalink?repo=fedora-38
This is how request is arriving at apt-cacher-ng
Using tinyproxy:
GET http://HTTPS:80///mirrors.fedoraproject.org/metalink?repo=fedora-38 HTTP/1.0
Host: HTTPS
Connection: close
Accept: */*
User-Agent: curl/8.0.1
Using apt-cacher-ng as proxy directly
GET http://HTTPS///mirrors.fedoraproject.org/metalink?repo=fedora-38 HTTP/1.1
Host: HTTPS
Accept: */*
Proxy-Connection: Keep-Alive
Not fully sure if the bug is on tinyproxy or apt-cacher-ng end, however I found libcurl violates RFC7230 when constructing a proxy request with an explicit port ":80" in the URL · Issue #6769 · curl/curl · GitHub and that :80 is the only relevant difference between these 2 requests, probably making apt-cacher-ng rewrite fail.
