I’m using Qubes OS 4.1 with latest updates.
After booting Qubes OS today, I don’t have the nm-applet anymore. WiFi still works as expected but because the network is already known and sys-net using fedora-37 and not fedora-37-dvm.
It seems I have an issue the default HVM vms, I can’t run programs in sys-net or sys-usb (created by default in a fresh install a few weeks ago) from the Xfce menu.
Running qvm-run -p sys-net uname from dom0 displays nothing but the terminal is still is qvm-run waiting for something.
I’m able to run gnome-terminal with the fedora-37 template.
I cloned sys-net, deleted the original one, and used sudo qubesctl state.apply qvm.sys-net to recreate it, and same problem happens
Same for sys-usb
I already experienced a similar behaviour with the gentoo template after fiddling with emerge, the template and inheriting VMs weren’t usable from dom0 from qvm-run or the xfce menu icons. But in the current case, I didn’t do anything special with the template.
any idea how I could debug this?
