This is the doc in question that I followed: Mullvad on Qubes OS 4 - Guides | Mullvad VPN
I followed this article and I successfully configured everything above DNS Hijacking. After following the DNS Hijacking section, something went wrong. I believe I successfully configured the /rw/config/qubes-firewall-user-script, although I have no idea how to verify it (or even what the purpose of it was). I believe where I went wrong was the qvm-firewall terminal settings where you have to manually configure the firewall rules.
I followed the instructions exactly, but after doing so I could not access the internet in AppVMs with MullvadVPN set as their NetVM. I figured out how to reset the firewall settings and I’m able to get internet again.
Before resetting the firewall, I used the AppVM terminal and pinged google.com, and it said the packets were filtered. I assume this is because the ICMP protocol was set to drop - I don’t know much about networking but I thought if you don’t accept ICMP then how are you going to receive a response from a server?
I believe the issue was with the IP addresses I entered. I used Servers | Mullvad VPN to reference the IP addresses I want to use (instead of using the OpenVPN configuration file). I added the IPV6 and IPV4 addresses, hoping the IPV6 would take priority where available. Can someone help me out?
