Just ordered first YubiKey 5 NFC, and was looking for guide how to setup it in Qubes OS for mostly Website logins and OTP…
Is the process starts from creating CTAP Proxy ( CTAP proxy — Qubes OS 4.3.1 documentation ) ?? Can I add to my YubiKey all OTP/passkey in other device and is it stored in YubiKeys device ?
I have few AppVM qubes I will use it with, eg. Banking AppVM, and Disposable Banking Qube based on Banking AppVM.
Asked Gemini how to setup it for disposables qubes and got this answer (it’s after he advice to create new qubes ‘sys-yubikey’ and installing ‘sudo dnf install qubes-u2f’ CTAP/U2F backend package in Template VM);
Step 1: Enable the Proxy Service on the Template
Since you can't manually run commands on a disposable qube before it boots, you must enable the CTAP/U2F proxy service on the underlying template so every spawned disposable inherits it automatically.
Run this in a dom0 terminal:
bash
qvm-service --enable Banking qubes-u2f-proxy
Use code with caution.
(Now, any disposable qube spawned from Banking will automatically have the client proxy running inside it.)
Step 2: Use the @dispvm: Syntax in the Dom0 Policy
To authorize these dynamic, randomized qubes without compromising security, you use the @dispvm:AppVM-Name syntax in your Qrexec policy.
This tells Qubes: "Allow any disposable qube to talk to sys-yubikey, but ONLY if it was spawned from the Banking templates."
1. Open your policy file in a dom0 terminal:
bash sudo nano /etc/qubes/policy.d/30-user.policy
2. Update or add lines specifically targeting the disposable environments using @dispvm::text
# Rules for Disposables spawned from the Banking Template u2f.Authenticate * @dispvm:Banking sys-yubikey allow ctap.GetInfo * @dispvm:Banking sys-yubikey allow ctap.ClientPin * @dispvm:Banking sys-yubikey allow
3. Save and close the file (Ctrl+O, Enter, Ctrl+X).
Why this is the ultimate setup:
By combining Disposable Qubes with your intermediate sys-yubikey proxy, you achieve maximum isolation:
1. Your browser state is completely wiped the moment you close your banking session.
2. Your USB stack remains isolated from your web browsers.
3. Malicious or random disposables cannot access your YubiKey because
dom0 explicitly filters access based strictly on the originating template (@dispvm:Banking).
Is The Gemini Helpful on that ?
