Is QubesOS compatible with WPA3 WLAN?
Hello i have a new Router with WPA3 Security. Is QubesOS working with them?
My connection dont work, with my old router was the connection working!
Not 110% sure if it could be an issue. I administrate my router to send WPA2+WPA3 signals and it’s working.
I guess it depends on the template you use in your netvm. You should first check whether it’s supported upstream or not.
