I mean, if I just put my hdd/ssd with Qubes installed into other machine, will it work just fine?
I cannot verify it myself right now.
if hw works
then I don’t think there’re any other problems…
of course encrypted disk needs its original pwd…
but that’s it…
cheers,
M.
Good point.
HW compatibility and PCI numbering changes.
If you have a device attached to sys-net that BUS numbering might be the
main display on another machine, or a disk controller.
If you want to do this, set all qubes not to autostart,and review the
device allocations before starting them. That can save unpleasant
surprises.
