Need to mount the windows hvm from an appvm to run some linux scripts.
Can anyone point me in the right direction please?
MSQLI via Qubes OS Forum qubes_os@forum.qubes-os.org writes:
I have tried to create a Manjaro template a while ago. For me, a standalone Windows machine is much easier to create then an AppVM, since AppVMs require a template.
Well, if it’s not important for you to integrate your VM with Qubes,I think my old post might help you.
Trying to do this, so not sure its relevant, but thanks,
Example: /dev/qubes_dom0/vm-debian-9-tmp-root
[user@dom0]$ dev=$(basename $(readlink /dev/YOUR_LVM_VG/YOUR_LVM_IMAGE))
[user@dom0]$ qubesdb-write /qubes-block-devices/$dev/desc “YOUR_LVM_IMAGE”
How do we find out the LVG image name/path?
What is “basename”?
- MSQLI
February 19Example: /dev/qubes_dom0/vm-debian-9-tmp-root
[user@dom0]$ qubesdb-write /qubes-block-devices/$dev/desc “YOUR_LVM_IMAGE”How do we find out the LVG image name/path?
Look at /dev/qubes_dom0/ ; from here the names should be pretty obvious.
What is “basename”?
It is a shell command, like readlink. So you can learn more about it
with :
$ man basename
or
$ man readlink
Anyway good luck with https://wiki.ameliorated.info ; that is
interesting, indeed ![]()
