I am a new user of Qubes OS R4.0 up to date on a Thinkpad X230.
I have an issue when I shutdown a virual machine by the Qube Manager or by the terminal inside the VM itself (shutdown -h now), the gui freeze and I only can move the mouse.
After that, I have to hold down the power button to turn off my computer.
I don’t know where I have to look to get more informations. I don’t understand where to find informations in /var/log.
Do you have an explanation and / or an idea to help me to solve this issue ?
The problem occure when I shutdown a specific appvm with 1TB of datas inside.
When I shutdown this appvm by the qubes manager in the GUI or when I use the command qvm-shutdown --all, the GUI freeze and If I use the second tty (ctrl +alt + f2) it doesn’t work anymore. I have to do an hardware shutdown.
I have no specific error in journalctl except this one :
qubes.WindowIconUpdater: personal -> dom0: denied: qrexec-client failed
Is there a way to fix this problem because I think that my datas will be damage after all these hard dirty shutdown…
You have a qube with 1TB data in private storage?
On an x230?
This seems so far outside the expected use that I’m not surprised your
system is at breaking point.
I do know people who run 1TB or more in private storage, but they use
machines adequate to the task.
Frankly, after the second (maybe the third) freeze, I would be looking
at alternative ways of organizing my data. Insanity is repeating the
same mistakes and expecting different results.
I find nothing about storage limitation. Also, I think that it is the usage, separate your digital life into domains, one of them is my personal domain with my familly photos and videos…
X230 have a litlle screen but an Intel i7 and 16 GB of ram with an 2 TB ssd. It’s not so bad for this use I think.
I did what you write.
In xentop I see dom0 and then the appvm personal. When I stop appvm personal, it close disapear from xentop but dom0 use 100% of cpu .
You have a 2TB SSD, and a qube with 1TB in private disk.
Look at the volumes under /dev/qubes-dom0
These are links to volumes under /dev
In particular look at vm-XXX-private and vm-XXX-private...-back
You could mount these in dom0.
Also, run qvm-volume info XXX:private, and look at “size”, “usage” and
“revisions_to_keep”.
Hello,
thank you for you message.
I have the following property :
revisions_to_keep 1
save_on_stop true
save_on_start false
I have 7 revisions to keep, it’s not logical isn’t it ?
Also, is it possible to set save_on_stop to false ? I don’t understand the purpose of save_on* property.
I have set save_on_stop to false, remove all lvm Snapshot, set revision_to_keep to 0 in qubes.xml, but after each dirty shutdown I have more than one revision and I still have the bug.
Do I have to create an issue on github or the problem is my use case ?
You should almost never have to edit qubes.xml directly. qvm-volume set qube:private revisions_to_keep 0 will stop saving
revisions.
You should see that any private-xxx-back volumes are gone - although given
the likely state of your system I would check this and make sure you
have sufficient space.
You might find it more reasonable to move the bulk of the data on to a
storage volume that you attach to the qube as you will.
