Inter-Qube Audio Devices
How would one go about piping audio from one qube to another, specifically linux to windows. I have a DAW running in a Windows VM and want to modulate input using pipewire, then pipe the audio to Windows.
I don’t know if there’s a “proper” way of doing it but I believe you should be able to set up a second audioVM, make that VM the audioVM of your Windows VM, do some processing and push the output into your audioVM’s virtual microphone device, then attach that microphone device to your Windows qube of choice.
