Intel NUC13ANHi5
layout:
  'hcl'
type:
  'mini pc'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  Intel(R) Client Systems
model: |
  NUC13ANHi5
bios: |
  ANRPL357.0027.2023.0607.1754
cpu: |
  13th Gen Intel(R) Core(TM) i5-1340P
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:a707]
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Device [8086:a7a0] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Device 51f1 (rev 01)
  Intel Corporation Device 125c (rev 04)
memory: |
  65084
scsi: |
  Samsung SSD 870  Rev: 2B6Q
usb: |
  4
versions:
- works:
    'yes'
  qubes: |
    R4.1
  xen: |
    4.14.5
  kernel: |
    6.3.9-1
  remark: |
    Suspend "works".  Resume does not.  Just reflashed BIOS from 0026 to 0027, so perhaps....
  credit: |
    QubesAnon
  link: |
    https://FIXLINK.example.com/InterestingStuff.html#wtf?
Remarks
Suspend works. Resume doesn’t. The power button just flashes tauntingly. Must be a BIOS issue I hope will eventually be fixed.
Initial install of 4.1.2 was hit by the “graphics really slow” issue, but reinstall with latest kernel boot-time option works fine.
I run a self-built version of the i3 wm (per Has anyone installed i3wm 4.22). This more or less re-installed from the copy I found in dom0 after I re-installed from backup.
My prior system was a NUC10i5FNH4 with 32GB memory. I restored a recent backup from that system and it took a few hours to tweak things back to how I like it with i3.
I don’t connect over WiFi but the WifiNetworks>AvailableNetworks displays my two Wifi SSIDs.
I also do not have a 2.5Gb ethernet switch but can attest to 1Gb connexion working.
Update on suspend/resume.
I booted my Tails ThumbDrive on this platform. Tails (most recent version) has no problems with suspend/resume. Both the power button and hitting a key on the USB keyboard resume.
Rebooted into Qubes and tried suspend again. No resume. Sad. Very sad.
Thank you @QubesAnon for your HCL report, which is online now!
