Intel NUC10i7FNK [Merged #1]
layout:
  'hcl'
type:
  'mini pc'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  Intel(R) Client Systems
model: |
  NUC10i7FNK
bios: |
  FNCML357.0057.2022.0520.1803
cpu: |
  Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:9b51]
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Comet Lake UHD Graphics [8086:9bca] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Comet Lake PCH-LP CNVi WiFi
  Intel Corporation Ethernet Connection (10) I219-V
memory: |
  65246
scsi: |
usb: |
  2
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.1
  xen: |
    4.14.5
  kernel: |
    5.18.9-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Remarks
Works well out of the box. There are two issues I had, one I haven’t resolved but it isn’t a show stopper. The first issue appeared at the end of the installation and was an issue with the Ethernet controller, specifically the “Unable to reset the PCI device..” the solution is here in the documentation. The other has to do when rebooting. Qubes finishes shutting everything down and when it hands over to reset the computer it just hangs. Shutting down works fine though.
The following are tested and work well:
  • Video
  • Networking - wired and wireless
  • sleep
Qubes-HCL-Intel_R__Client_Systems-NUC10i7FNK-20220809-083752.yml (815 Bytes)
2 posts were merged into an existing topic: Intel NUC10i7FNK
