Intel NUC 8i5BEH1 : how to attach the ethernet device to sys-net?
hi Guy I’ve the same issue in Acer A515-52-56UN Q4.1 RC2
 dom0 $ qvm-start sys-net: Start failed: internal error: Unable to reset PCI device 0000:01:00.1: internal error: Active 0000:01:00.1 devices on  0000:01:00.1, not doing bus reset,
Solved following PCI troubleshooting | Qubes OS PCI troubleshooting
You can also configure strict reset directly from the Qubes interface by following these steps:
Go to the sys-net VM settings
Go to Devices
Make sure the device is in the right field
Click “Configure strict reset for PCI devices”
Select the device, click OK and Aply
Thank you to the great Q Team
