Hello can I start by thanking those that take the time to read this message.
Since becoming more security conscience I’m trying to use Qubes Os for all my communications. I wish to use signal on my computer without a phone, so that I can still interact with normal people.
Ive spent a good few days now working on installing signal-cli and cli in Qubes OS and researching on the web and I’m running into a problem.
Here’s what I’m doing;
#Installed dependencies for signal-cli and cli in a whonix ws template vm.
#Created AppVM from the whonix ws template.
#Installed signal-cli and cli in the /home/user directory of the AppVM.
#Registered an account with signal using a sim in the cloud service.
I can both send and receive messages using the cli terminal user interface, I can also receive and send messages directly using signal-cli -a ACCOUNT receive command.
The problem is as soon as I close the terminal window and re-open, both the sent and the received messages are gone. Its seems that signal-cli is sending and receiving all messages, however it isn’t saving the conversations.
I suspect that this is a case of user error, the solution is probably very simple, that being said I’m stuck!
Any help would be greatly appreciated.
Many thanks.
