Installing nftables inside disp sys-dns
1… goal:
…installed nftables in templatevm debian-12-xfce
… run them in disp q sys-dns…(disp q sys-dns has 2 templates if that matters)
2… templatevm:
…created “/etc/nftables.conf”
… added nftables
TEMPLATEVM DEBIAN-12-XFCE:
  1. sudo apt install nftables
  2. sudo nano /etc/nftables.conf
  3. added nftables to #2
SYS-DNS:
  1. create directory:
    …sudo mkdir -p /rw/config/nftables
  2. create nftables file:
    …sudo nano /rw/config/nftables/rules.nft
  3. add nftables to #2
4… create file for loading rules to boot auto:
…sudo nano /rw/config/rc.local
5… add to #4:
…nft -f /rw/config/nftables/rules.nft
  1. sudo chmod +x /rw/config/rc.local
  2. sudo systemctl enable nftables
  3. sudo systemctl start nftables
  4. sudo nft list ruleset
Shouldn’t this be nft -f /rw/config/nftables/rules.nft?
thx…it was just a typo in my post!
Nftables is already preinstalled in the default debian-12-xfce template.
You should add your custom firewall rules here:
Yeah, i looked at them, but limited success…
Can anyone glance at this & see either why rules not staying persistent or say whether or not rules need to bewritten in sys-dns or copied over from templatevm…?
Did this previously w/success. This time close but something is off…
thanks
If your sys-dns is a named disposable, then you need to make changes in its disposable template.
For example, sys-dns template is set to default-dvm disposable template and the template of default-dvm is debian-12-xfce.
You need to make changes in default-dvm app qube or in debian-12-xfce template.
