Hey, I need some help installing gentoo Template.
Try using qubes 4.1 and simply install from qubes repo, and you can be more specific about the problem.
I am using qubes 4.0.4, and while I was installing the gentoo template, via the dom0, it said no match found.
yes because there’s no gentoo package in there, you need to use 4.1 or manually install.
manually, you mean, by the ISO builder?
Yes, as example is Contents/building-archlinux-template.md at master · Qubes-Community/Contents · GitHub
sure. thank you very much for the information.
(edited title for clarity)
