Installing, Configuring & Using signal-cli in Qubes OS
Installing signal-cli
Step 1: Install Java on the Template
First, install Java 26 on the template that your signal-cli AppVM will be based on.
For Whonix Workstation or Debian:
export https_proxy=http://127.0.0.1:8082/
wget https://download.oracle.com/java/26/latest/jdk-26_linux-x64_bin.deb
sudo dpkg -i jdk-26_linux-x64_bin.deb
For Fedora:
wget https://download.oracle.com/java/26/latest/jdk-26_linux-x64_bin.rpm
sudo rpm -i jdk-26_linux-x64_bin.rpm
Shutdown the template after the JDK 26 installation is complete.
Step 2: Create and Start the AppVM
Now create an AppVM based on this updated template and open a terminal inside it.
Step 3: Download signal-cli
Download the latest signal-cli by running the following command:
wget https://github.com/AsamK/signal-cli/releases/download/v0.14.2/signal-cli-0.14.2.tar.gz
Step 4: Extract signal-cli
Extract the downloaded archive with this command:
tar xvf signal-cli-0.14.2.tar.gz
Step 5: Update the PATH Environment Variable
Run the appropriate commands below to add signal-cli to your PATH.
For Whonix Workstation 18:
echo 'export PATH="$PATH:$HOME/signal-cli-0.14.2/bin/"' >> ~/.zshrc
source ~/.zshrc
For Fedora or Debian-based AppVMs:
echo 'export PATH="$PATH:$HOME/signal-cli-0.14.2/bin/"' >> ~/.bashrc
source ~/.bashrc
Step 6: Verify the Installation
Check the installed version with:
signal-cli --version
Registering a Signal Account on signal-cli Behind Tor Using a Virtual Number
To register a Signal account on signal-cli, solving a captcha challenge on a browser is required. Both the browser and the terminal must connect to the Signal server using the same IP address; otherwise the Signal server will mark the captcha as invalid.
Similarly, in the case of virtual numbers, sometimes (not always) the virtual number does not receive the verification code if your IP address (in the case of Tor, the IP address of the Exit node) is not from the same country as the virtual number. That’s why fixing the exit node to a static IP is required to register a Signal account on signal-cli using Tor.
Configuring sys-whonix
Fixing the exit node in sys-whonix requires root privileges and in Whonix 18 you can’t do it in normal user mode. So follow these steps:
  1. Shutdown sys-whonix.
  2. Go to sys-whonix VM settings → Advanced Tab.
  3. In Boot Mode set: PERSISTENT Mode – UNRESTRICTED Session.
  4. Click OK and start sys-whonix again.
  5. Open sys-whonix → Tor User Config.
  6. A text file will open. Write the following at the end of the text file:
    ExitNodes {gb}
    StrictNodes 1
    Where {gb} is for Great Britain (United Kingdom). This is just an example. Use the country of your virtual number instead. For example {nl} for Netherlands, {ca} for Canada, etc.
  7. Save and close the text file then Reload Tor (sys-whonix → Reload Tor).
  8. Open Onion Circuits (Tor Control Panel → Utilities Tab → Onion Circuits Button).
  9. Click on a connected circuit and verify the exit node is from the same country as you defined in the Tor User Config.
  10. Do something on the internet to create new circuits. Click on a “Succeeded” circuit and copy the IP address of the Exit node.
  11. Open Tor User Config again and replace {gb} or whatever the country code is with the IP address like this:
    ExitNodes 212.38.189.186
    StrictNodes 1
  12. Save and close the text file and reload Tor.
Now your Tor is configured to register a Signal account using signal-cli.
Caution: Don’t do any other internet activity behind Tor after this, just use it to register the Signal account. Otherwise all of your internet traffic will go through a single exit node.
Registering the Signal Account
  1. Open a browser in your signal-cli VM and browse the following link:
    Signal
  2. Solve the captcha challenge. After solving the captcha challenge it will show a link “Open Signal”.
  3. Right-click on the link and copy the link address.
  4. In the signal-cli terminal, give the following command to register and press Enter:
    signal-cli -a PHONENUMBER register --captcha "CAPTCHACODE"
    Where:
    • Type your virtual number starting with + in place of PHONENUMBER.
    • Paste the copied link address from “Open Signal” in place of CAPTCHACODE.
    • Make sure to put " before and after the captcha code.
Caution: The captcha code is only valid for less than a minute, so do this process within this time.
  1. If all goes well then you will receive a verification code. Type the following command to verify:
    signal-cli -a PHONENUMBER verify CODE
    Type the verification code you received in place of CODE.
  2. Your account is now registered. You can confirm it by giving the following command:
    signal-cli listAccounts
Configuring the Signal-cli Account
If you have only one account in your signal-cli, you will not need to provide your phone number every time you give a command. Otherwise you will have to provide your phone number every time you give a command.
The first command you need to provide after registration is this:
signal-cli receive
If you have multiple accounts in your signal-cli then:
signal-cli -a PHONENUMBER receive
Other configuration commands:
  • To set your name:
    signal-cli updateProfile --name "YOUR NAME"
  • To enable read receipts (This is required to enable for your linked desktop device too, you can’t enable it from the linked desktop device.):
    signal-cli updateConfiguration --read-receipts true
  • To enable typing indicators:
    signal-cli updateConfiguration --typing-indicators true
  • To enable link previews:
    signal-cli updateConfiguration --link-previews true
Linking Signal Desktop App with signal-cli
Signal Desktop app shows a QR code to link it with the parent device. This code is displayed for 30 seconds. You need to extract the QR code from the QR image and paste it in the signal-cli command within these 30 seconds.
If your Signal Desktop is in a separate VM than your signal-cli (which is recommended) then the steps will increase. You will need to take a screenshot of the QR image. The screenshot file will be saved in dom0. You need to copy it to your signal-cli VM from dom0. Then you need to give the image to an online QR scanner to extract the code. Then you will type the command in signal-cli to link the desktop device and paste the QR code there.
All this must be done within 30 seconds or the QR code will change. So here’s the trick:
Don’t open Signal Desktop app yet.
  1. In signal-cli terminal type the following command but don’t press Enter:
    signal-cli addDevice --uri "
  2. In signal-cli browser open the following address or any QR scanning website you know:
    https://scanqr.org
  3. Open dom0 terminal and go to Pictures directory:
    cd ~/Pictures
  4. Type the following command but don’t press Enter:
    (Where signal-cli is the name of your signal-cli VM, while qr.png is the screenshot file name that you will generate shortly.)
  5. Now when everything is in place, open Signal Desktop App. It will show the QR image.
  6. Press Print Screen button and take the screenshot of only the QR image region and save the file with the name qr.png in the default location which is the Pictures directory in dom0.
  7. In dom0 terminal just press Enter (the command is already typed there).
  8. In the scanqr website opened in the browser of signal-cli VM, select the qr.png file from /home/user/QubesIncoming/dom0/.
  9. The website will show the extracted QR code. Copy the code.
  10. In signal-cli terminal paste the extracted QR code in the already typed command after " and after pasting the code type another " and press Enter. The command will look like this:
    signal-cli addDevice --uri "QRCODE"
    Where your extracted QR code will be in place of QRCODE.
Signal Desktop app will start linking with the signal-cli.
Automating signal-cli
You normally don’t need to use signal-cli, you just need to link it with your desktop client. But it is required that the receive command should run frequently in signal-cli because:
  1. If you didn’t run the receive command in signal-cli for 45 days your desktop client will unlink.
  2. Signal server keeps the encrypted messages if the parent device or any linked device didn’t receive the message. When you run the receive command, signal-cli fetches the messages from the server, just displays them using stdout but doesn’t save them to the disk. If a parent device or any linked device don’t receive messages the Signal server will retain messages up to 45 days and the messages will be deleted after that.
So for frequently running the receive command we’ll put the receive command in a script and make it autostart on login.
Signal-cli doesn’t save messages on local storage but it does store attachments, stories, avatars and stickers. Similarly when the parent device and all the linked devices receive the message the Signal server deletes the message but the server doesn’t delete the attachments, stories, avatars and stickers. It automatically deletes them after 45 days from the server.
So there is no need to download these attachments, stories, avatars and stickers. They will just use disk space and will be of no use. So we’ll skip them in the receive command.
Create a signal-receive.sh file and open it in editor:
nano signal-receive.sh
Paste the following in the editor:
On Whonix Workstation 18:
qterminal -e "zsh -ic 'signal-cli receive --ignore-attachments --ignore-stories --ignore-avatars --ignore-stickers; signal-cli receive --ignore-attachments --ignore-stories --ignore-avatars --ignore-stickers; exit;'"
On Debian or Fedora:
xfce4-terminal -e "bash -ic 'signal-cli receive --ignore-attachments --ignore-stories --ignore-avatars --ignore-stickers; signal-cli receive --ignore-attachments --ignore-stories --ignore-avatars --ignore-stickers; exit;'"
The command is ignoring all the attachments, stories, avatars and stickers. I provided the command two times because while using it behind Tor sometimes Tor takes time creating new circuits and the command times out in that period. So giving the command two times is for fail-safe. This command will open a new terminal, start receiving messages from server, display them on the terminal, do it two times then exit the terminal.
Make it executable:
chmod +x signal-receive.sh
Now to run this script on VM startup create an autostart folder in .config directory:
mkdir -p ~/.config/autostart
Create a desktop file to run the signal-receive.sh script on VM startup:
nano ~/.config/autostart/signal-receive.desktop
Paste the following:
[Desktop Entry]
Type=Application
Exec=/bin/bash -c "sleep 300 && /home/user/signal-receive.sh"
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name=Signal Receive
Comment=Runs signal-cli receive at startup
I’ve added a 300 seconds delay to run the script. Because we’ll set this VM to boot on startup. So the 300 is for safety so that the system, internet and Tor will connect properly and then this script will run. Otherwise if we run it immediately on startup the commands will probably time out.
Now in the signal-cli VM settings check the boot on startup checkbox.
It will be best if after running the receive script the signal-cli VM shuts down automatically because it will be of no use after that. For that check the “Shutdown when Idle for more than 15 minutes” checkbox in your signal-cli VM settings.
If this checkbox is disabled you need to install the package in your template first.
Open your template’s terminal and install it with the following command:
For Whonix & Debian:
sudo apt install qubes-app-shutdown-idle
For Fedora:
sudo dnf install qubes-app-shutdown-idle
Shutdown the template after installation.
Now check the “Shutdown when idle for more than 15 minutes” checkbox.
After these settings, on your system startup the signal-cli process will run in the following steps:
  1. Signal-cli VM will start on system startup.
  2. After 5 minutes (300 seconds) the receive script will start.
  3. The receive command will run, show the received messages in terminal and then the terminal will exit.
  4. The signal-cli VM will shutdown after 15 minutes of running the script.
With this setup the user will not need to do anything with the signal-cli. It will become like a service that automatically runs and stops.
Troubleshooting during Registration
During registration sometimes Signal doesn’t accept VOIP virtual numbers of some countries. It will show an authentication error. You need to change the country and use a virtual number of some other country, or use a virtual number that is not VOIP.
Sometimes the Tor exit node that you are using gets blocked. As a result signal-cli always displays “Captcha Invalid” or “Authentication Error”. Change the exit node.
If your initial try of registration failed and you changed the virtual number, the signal-cli will keep the failed number in the database. Then you will not be able to use signal-cli account commands (like receive or account configuration commands) without providing -a PHONENUMBER.
To check if you have failed phone numbers give the following command:
This command will display your registered number and also the failed numbers.
To delete the failed numbers give the following command:
signal-cli -a PHONENUMBER deleteLocalAccountData --ignore-registered
Replace PHONENUMBER with your failed phone number in signal-cli.
The --ignore-registered option will ignore the registered number if you have provided the registered number accidentally instead of the failed number.
Alternative Installation Method using Flatpak for Automatic Updates
You can install signal-cli using Flatpak. This way, you won’t need to install updates manually — signal-cli will be automatically upgraded along with your Qubes OS updates.
Note: You must first follow the Flatpak integration in Qubes OS Community guide by @solene before proceeding:
Installing signal-cli using Flatpak
You need to install it in your TemplateVM (not in an AppVM).
  1. Open your signal-cli TemplateVM and run the following command:
    flatpak install flathub org.asamk.SignalCli
  2. Once the installation is complete, run:
    sudo flatpak override --filesystem=/tmp org.asamk.SignalCli
  3. Shut down the TemplateVM.
Running signal-cli
signal-cli installed via Flatpak is normally run with this long command:
flatpak run org.asamk.SignalCli
To make it available simply as signal-cli, do the following in your signal-cli AppVM:
mkdir -p ~/.local/bin
cat > ~/.local/bin/signal-cli << 'EOF'
#!/bin/sh
exec flatpak run org.asamk.SignalCli "$@"
EOF
chmod +x ~/.local/bin/signal-cli
Important: Data Location Change
With the Flatpak installation of signal-cli, account data is not stored in ~/.local/share/signal-cli. Instead, it is stored in:
~/.var/app/org.asamk.SignalCli/data/signal-cli/
If you have an existing signal-cli installation, move your data to the new location.
Update your PATH
Add the new signal-cli wrapper to your PATH:
echo 'export PATH="$HOME/.local/bin:$PATH"' >> ~/.zshrc
source ~/.zshrc
Your signal-cli is now installed via Flatpak and will update automatically with your Qubes Template updates. No manual upgrades are required anymore.
virtual numbers
Where do can I get them?
virtual numbers
Where can I get them?
I’ve tried many services, but the most reliable one I’ve found is http://buynumber.io. They accept cryptocurrencies including XMR, and their prices are very cheap.
Their customer service used to be very good, but it has become poor recently. Apart from that, there are no issues with the services they provide.
Thanks. I don’t use cryptocurrencies, so I guess no way to do it.
I meant to say they also accept cryptocurrencies.
JMP has a list of their competitors, including their FLOSS status. Not sure which of these provide numbers outside of N.America. I know JMP has talked about expanding. I’m not sure where that stands, but there is this EU list, so maybe worth asking them. They accept all kinds of payment, including cash.
What happens if such virtual number is necessary after registering an account. E.g. for some security verification in case of incident. If it is a number that is used by many, that won’t work. If it is a one-time number, it won’t work either. How does this work?
Treating a virtual number as a burner means the signal account should also be treated as a throwaway. In practice though, it could be good as long as you maintain signal on the original device (I haven’t tried this with signal cli in a qube, so ymmv). You should not expect backups or migration to another device to work without maintaining the number for verification.
JMP, and I’m sure most voip providers, assume you will keep the number indefinitely and charge periodically, but, as with the carriers, you can always drop the service. JMP in particular can be used with standard templates in Qubes, because it provides a bridge between XMPP and the phone network, so provides phone connectivity with linux based clients like Dino and Gajim. Reliability may be an issue, but simple SMS confirmations should just work.
Thanks for explaining.
It is particularly strange how supposedly privacy-focused apps deliberately tie usage to anti-privacy technology.
Many dimensions to privacy with messaging apps. Signal is excellent at some, but not all (for example, PFS and encryption, but not metadata or verification). I’m curious if the signal-cli is built without the questionable Google libraries included in the official Signal client, like Molly provides for Android. There’s also the backend infrastructure, which relies on Google, Amazon, and Cloudflare, for better or worse, some of which one can block in Qubes…
Dear SignaCli not updated automaticly in flatpak what will be the issu e
Do this in the template:
sudo chmod +x /etc/qubes/post-install.d/05-flatpak-update.sh
For an alternative approach, here’s what I did to get signal-cli working on a debian 13 minimal template + appvm combo, linking it to a Signal account that has already been setup.
  • Open root terminal for template
  • $ sudo apt install qubes-core-agent-networking thunar qubes-core-agent-thunar curl wget -y
  • $ Install Java 26: $ export https_proxy=http://127.0.0.1:8082/ && wget https://download.oracle.com/java/26/latest/jdk-26_linux-x64_bin.deb && sudo dpkg -i jdk-26_linux-x64_bin.deb && rm -rf jdk-26_linux-x64_bin.deb
  • Create appvm, open normal terminal
  • See newest version of signal-cli: $ curl -s https://api.github.com/repos/AsamK/signal-cli/releases/latest | grep tag_name
  • $ wget https://github.com/AsamK/signal-cli/releases/download/v0.14.4.1/signal-cli-0.14.4.1.tar.gz && tar xvf signal-cli-0.14.4.1.tar.gz && rm -rf signal-cli-0.14.4.1.tar.gz
    • Update numbers if newer version exists
  • $ echo ‘export PATH=“$PATH:$HOME/signal-cli-0.14.4.1/bin/”’ >> ~/.bashrc
  • $ source ~/.bashrc
  • Verify installation worked: $ signal-cli --version
  • To link new device, open a 2nd Xterm terminal: $ xterm -fa ‘DejaVu Sans Mono’ -fs 12
  • $ signal-cli link -n “signal1”
  • Scan QR code on mobile app where Signal is already setup
  • Close 2nd Xterm
  • In 1st Xterm, send a test msg (will appear in “Note to Self”): $ signal-cli -a +NUMBER send -m “Test msg from CLI” +NUMBER
    • Replace +NUMBER with your Signal number including prefix
  • Make signal-cli start automatically:
    • $ mkdir -p ~/.config/systemd/user/
    • $ cat > ~/.config/systemd/user/signal-cli.service << ‘EOF’
    • Paste below (edit NUMBER) then press Enter to close:
[Unit]
Description=Signal CLI Daemon
After=network.target
[Service]
Type=simple
ExecStart=/home/user/signal-cli-0.14.4.1/bin/signal-cli --account +NUMBER daemon --http 127.0.0.1:8080
Restart=on-failure
RestartSec=5
StandardOutput=journal
StandardError=journal
[Install]
WantedBy=default.target
EOF
  • Verify it saved correctly $ cat ~/.config/systemd/user/signal-cli.service
  • $ systemctl --user daemon-reload
  • $ systemctl --user enable signal-cli
  • $ systemctl --user start signal-cli
  • Check status: $ systemctl --user status signal-cli
  • View logs (you’ll see msgs in there too): $ journalctl --user -u signal-cli -f
Note you’ll need to update signal-cli every 2-3 months. Signal-cli stops working if it’s older than ~3 months because Signal servers reject old clients.
