I’m confused in regards to Qubes compatibility with Macbook Pro (2018, Intel Core i9, AMD Radeon, SSD).
Is it possible, without involved debugging, to set up a Qubes on such machine with bluetooth apple mouse while preserving the existing Mac OS X installation which I’ll need to use from time to time? If so, how does it work and is there a specific guide with clear step by step instructions?
Also, I read various discussions about running OS X as a VM on Qubes but they were old and I’m not sure if it’s possible with the latest Qubes OS or not.
Thank you
