Really confused here, I was able too install QUBES OS once, but I didn’t have immou enabled so I couldn’t open up whonix etc, so I enabled it and went for another install, now it just freezes at “set up network” during initial install and when I try too reboot and put in my disk password I’m just met with a frozen black screen with my cursor, I’ve tried updating my WiFi card(I think successfully) which is a Broadcom 43c3, I’m also on a Asrock b450m Pro4 motherboard, and I also noticed I’m met with a “usb in dom0 is not restricted” when I first boot things up, this is pretty much out of my league at this point, and I’ve tried too install several different times, cleared my hard drives cause I’m installing with 2 usbs, I just can’t get anything too work I haven’t been able too find any similar issues online and when I have found somewhat similar issues, the fixes just don’t work for me, I’m super confused and lost please help. My last resort is getting a m2 ssd and trying it that way.
Note the very last sentence.
I’ve looked all over my bios and can’t find any setting to disable my network card, I also looked around and was told the 43c3 should be compatible with qubes is, I let it do a install over night and when I woke up I got a new error message this time saying that “qubes os can’t configure check dom0”
Well I don’t know what happened I got a config error and now my Qubes Os works as far as logging in with no black screen, seems like disabling create default qubes fixed my issues, gonna try too use some qubes etc and let you know from there
Starting too get these messages, any advice?
Gonna try too run some commands through dom0, if issue persist do yall recommended downloading qubes through a ssd?, I’ve been hearing that sys-usb/usb installs in general can be a pain
Do you have sys-firewall and sys-net system qubes?
I don’t see them, I think the first post you sent was right, my 43c3 Broadcom is more than likely incompatible
