.xsession_errors has the following erros:
Environment variable $XAUTHORITY not set, ignoring.
Failed to read /guivm-windows-prefix
** Message: 15:13:36.385: couldn't access control socket: /run/user/1000/keyring/control: No such file or directory
discover_other_daemon: 0** Message: 15:13:36.389: couldn't access control socket: /run/user/1000/keyring/control: No such file or directory
discover_other_daemon: 0SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
Not in GuiVM or dom0. Exiting.
discover_other_daemon: 1SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
2023-06-24 15:13:36.727 qrexec-fork-server[778]: qrexec-agent-data.c:244:handle_new_process_common: executed: QUBESRPC qubes.StartApp+org.gnome.Terminal dom0 (pid 787)
(xfce4-notifyd:751): Gdk-CRITICAL **: 15:13:37.113: gdk_atom_intern: assertion 'atom_name != NULL' failed
2023-06-24 15:13:37,132 icon-sender: running: ['qrexec-client-vm', 'dom0', 'qubes.WindowIconUpdater']
(gsd-xsettings:763): Gdk-CRITICAL **: 15:13:37.160: gdk_atom_intern: assertion 'atom_name != NULL' failed
(gsd-xsettings:763): xsettings-plugin-WARNING **: 15:13:37.644: Failed to get current display configuration state: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
(evolution-alarm-notify:712): Gdk-CRITICAL **: 15:13:37.859: gdk_atom_intern: assertion 'atom_name != NULL' failed
(kalendarac:731): Gdk-CRITICAL **: 15:13:38.846: gdk_atom_intern: assertion 'atom_name != NULL' failed
(gsd-xsettings:763): xsettings-plugin-WARNING **: 15:13:39.094: Unable to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
(akonadi_control:898): Gdk-CRITICAL **: 15:13:39.110: gdk_atom_intern: assertion 'atom_name != NULL' failed
(evolution-alarm-notify:712): Gdk-WARNING **: 15:13:39.979: ../gdk/x11/gdkproperty-x11.c:224 invalid X atom: 1789888422
(kalendarac:731): Gdk-WARNING **: 15:13:39.979: ../gdk/x11/gdkproperty-x11.c:224 invalid X atom: 1789888422
(xfce4-notifyd:751): Gdk-WARNING **: 15:13:40.009: ../gdk/x11/gdkproperty-x11.c:224 invalid X atom: 1789888422
(gsd-xsettings:763): Gdk-WARNING **: 15:13:40.010: ../gdk/x11/gdkproperty-x11.c:224 invalid X atom: 1789888422
(akonadi_control:898): Gdk-WARNING **: 15:13:40.169: ../gdk/x11/gdkproperty-x11.c:224 invalid X atom: 1789888422
Installing MariaDB/MySQL system tables in '/home/user/.local/share/akonadi/db_data/' ...
OK
To start mariadbd at boot time you have to copy
support-files/mariadb.service to the right place for your system
Two all-privilege accounts were created.
One is root@localhost, it has no password, but you need to
be system 'root' user to connect. Use, for example, sudo mysql
The second is user@localhost, it has no password either, but
you need to be the system 'user' user to connect.
After connecting you can set the password, if you would need to be
able to connect as any of these users with a password and without sudo
See the MariaDB Knowledgebase at https://mariadb.com/kb
You can start the MariaDB daemon with:
cd '/usr' ; /usr/bin/mariadb-safe --datadir='/home/user/.local/share/akonadi/db_data/'
You can test the MariaDB daemon with mysql-test-run.pl
cd '/usr/share/mysql-test' ; perl mariadb-test-run.pl
Please report any problems at https://mariadb.org/jira
The latest information about MariaDB is available at https://mariadb.org/.
Consider joining MariaDB's strong and vibrant community:
https://mariadb.org/get-involved/
/usr/bin/mysqlcheck: Got error: 1049: Unknown database 'akonadi' when selecting the database
The xorg log:
[ 18.517]
X.Org X Server 1.20.14
X Protocol Version 11, Revision 0
[ 18.517] Build Operating System: 6.2.9-200.fc37.x86_64
[ 18.517] Current Operating System: Linux disp5057 5.15.103-1.qubes.fc32.x86_64 #1 SMP Wed Mar 22 17:36:35 CET 2023 x86_64
[ 18.517] Kernel command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 xen_scrub_pages=0
[ 18.517] Build Date: 25 April 2023 12:00:00AM
[ 18.517] Build ID: xorg-x11-server 1.20.14-23.fc37
[ 18.517] Current version of pixman: 0.40.0
[ 18.517] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 18.518] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 18.518] (==) Log file: "/home/user/.local/share/xorg/Xorg.0.log", Time: Sat Jun 24 15:13:34 2023
[ 18.521] (++) Using config file: "/etc/X11/xorg-qubes.conf"
[ 18.521] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 18.522] (==) ServerLayout "Default Layout"
[ 18.522] (**) |-->Screen "Screen0" (0)
[ 18.523] (**) | |-->Monitor "Monitor0"
[ 18.523] (**) | |-->Device "Videocard0"
[ 18.523] (**) |-->Input Device "qubesdev"
[ 18.523] (==) Automatically adding devices
[ 18.523] (==) Automatically enabling devices
[ 18.523] (==) Automatically adding GPU devices
[ 18.523] (==) Automatically binding GPU devices
[ 18.523] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 18.523] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 18.523] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 18.523] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 18.523] (II) Loader magic: 0x56aaf7ccea40
[ 18.523] (II) Module ABI versions:
[ 18.523] X.Org ANSI C Emulation: 0.4
[ 18.523] X.Org Video Driver: 24.1
[ 18.523] X.Org XInput driver : 24.1
[ 18.523] X.Org Server Extension : 10.0
[ 18.524] (++) using VT number 7
[ 18.524] (--) controlling tty is VT number 7, auto-enabling KeepTty
[ 18.526] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 18.526] (II) no primary bus or device found
[ 18.526] (II) "glx" will be loaded by default.
[ 18.526] (II) LoadModule: "fb"
[ 18.527] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 18.531] (II) Module fb: vendor="X.Org Foundation"
[ 18.531] compiled for 1.20.14, module version = 1.0.0
[ 18.531] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.531] (II) LoadModule: "glx"
[ 18.531] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 18.544] (II) Module glx: vendor="X.Org Foundation"
[ 18.544] compiled for 1.20.14, module version = 1.0.0
[ 18.544] ABI class: X.Org Server Extension, version 10.0
[ 18.544] (II) LoadModule: "dummyqbs"
[ 18.544] (II) Loading /usr/lib64/xorg/modules/drivers/dummyqbs_drv.so
[ 18.546] (II) Module dummyqbs: vendor="X.Org Foundation"
[ 18.546] compiled for 1.20.14, module version = 0.3.6
[ 18.546] Module class: X.Org Video Driver
[ 18.546] ABI class: X.Org Video Driver, version 24.1
[ 18.546] (II) LoadModule: "qubes"
[ 18.546] (II) Loading /usr/lib64/xorg/modules/drivers/qubes_drv.so
[ 18.547] (II) Module qubes: vendor="X.Org Foundation"
[ 18.547] compiled for 1.20.14, module version = 0.0.1
[ 18.547] Module class: X.Org XInput Driver
[ 18.547] ABI class: X.Org XInput driver, version 24.1
[ 18.547] (II) DUMMYQBS: Driver for Dummy chipsets: dummy
[ 18.547] (WW) Falling back to old probe method for dummyqbs
[ 18.547] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 18.547] (II) DUMMYQBS(0): Chipset is a DUMMY
[ 18.547] (**) DUMMYQBS(0): Depth 24, (--) framebuffer bpp 32
[ 18.547] (==) DUMMYQBS(0): RGB weight 888
[ 18.547] (==) DUMMYQBS(0): Default visual is TrueColor
[ 18.547] (==) DUMMYQBS(0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.547] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 18.547] (**) DUMMYQBS(0): Option "GUIDomID" "0"
[ 18.547] (**) DUMMYQBS(0): VideoRAM: 8101 kByte
[ 18.547] (--) DUMMYQBS(0): Max Clock: 300000 kHz
[ 18.547] (II) DUMMYQBS(0): Monitor0: Using hsync range of 49.00-50.00 kHz
[ 18.547] (II) DUMMYQBS(0): Monitor0: Using vrefresh range of 46.00-47.00 Hz
[ 18.547] (II) DUMMYQBS(0): Clock range: 11.00 to 300.00 MHz
[ 18.547] (II) DUMMYQBS(0): Not using default mode "640x350" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "320x175" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "640x400" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "320x200" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "720x400" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "360x200" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "640x480" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "320x240" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "800x600" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "400x300" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1024x768i" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "512x384i" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1024x768" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "512x384" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1152x864" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "576x432" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1280x960" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1280x1024" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "640x512" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1600x1200" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1792x1344" (insufficient memory for mode)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "896x672" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1856x1392" (insufficient memory for mode)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "928x696" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1920x1440" (insufficient memory for mode)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "960x720" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "832x624" (vrefresh out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "416x312" (vrefresh out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "1400x1050" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "700x525" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "2048x1536" (insufficient memory for mode)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "640x360" (hsync out of range)
[ 18.547] (II) DUMMYQBS(0): Not using default mode "320x180" (bad mode clock/interlace/doublescan)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "640x360" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "320x180" (bad mode clock/interlace/doublescan)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "720x405" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "360x202" (bad mode clock/interlace/doublescan)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "360x202" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "864x486" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "432x243" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "960x540" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "480x270" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1024x576" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "512x288" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1280x720" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1368x768" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "684x384" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1600x900" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "800x450" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1920x1080" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "2048x1152" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "2560x1440" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "2880x1620" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1440x810" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "3200x1800" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "3840x2160" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "4096x2304" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "5120x2880" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "7680x4320" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "15360x8640" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1280x800" (vrefresh out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "640x400" (vrefresh out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1400x900" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "700x450" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1680x1050" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "840x525" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1920x1200" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "960x600" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "2560x1600" (insufficient memory for mode)
[ 18.548] (II) DUMMYQBS(0): Not using default mode "1280x800" (hsync out of range)
[ 18.548] (II) DUMMYQBS(0): Virtual size is 1920x1080 (pitch 1920)
[ 18.548] (**) DUMMYQBS(0): *Mode "QB1920x1080": 96.0 MHz, 49.9 kHz, 46.1 Hz
[ 18.548] (II) DUMMYQBS(0): Modeline "QB1920x1080"x46.1 96.00 1920 1921 1922 1923 1080 1081 1082 1083 (49.9 kHz z)
[ 18.548] (==) DUMMYQBS(0): DPI set to (96, 96)
[ 18.548] (II) Loading sub module "fb"
[ 18.548] (II) LoadModule: "fb"
[ 18.548] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 18.548] (II) Module fb: vendor="X.Org Foundation"
[ 18.548] compiled for 1.20.14, module version = 1.0.0
[ 18.548] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.548] (II) Loading sub module "ramdac"
[ 18.548] (II) LoadModule: "ramdac"
[ 18.548] (II) Module "ramdac" already built-in
[ 18.551] (II) DUMMYQBS(0): Output DUMMY0 using monitor section Monitor0
[ 18.551] (II) DUMMYQBS(0): Output DUMMY0 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85eb5d0) and output DUMMY0 (0x56aaf85ec0a0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY1 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85ec500) and output DUMMY1 (0x56aaf85ecfd0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY2 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85ed3f0) and output DUMMY2 (0x56aaf85edec0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY3 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85ee2e0) and output DUMMY3 (0x56aaf85eedb0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY4 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85ef200) and output DUMMY4 (0x56aaf85efcd0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY5 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f00f0) and output DUMMY5 (0x56aaf85f0c00)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY6 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f1060) and output DUMMY6 (0x56aaf85f1b30)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY7 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f1f50) and output DUMMY7 (0x56aaf85f2a70)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY8 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f2ee0) and output DUMMY8 (0x56aaf85f39b0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY9 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f3dd0) and output DUMMY9 (0x56aaf85f4900)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY10 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f4d80) and output DUMMY10 (0x56aaf85f5850)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY11 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f5c70) and output DUMMY11 (0x56aaf85f67b0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY12 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f6c40) and output DUMMY12 (0x56aaf85f7710)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY13 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f7b30) and output DUMMY13 (0x56aaf85f8680)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY14 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f8b20) and output DUMMY14 (0x56aaf85f95f0)
[ 18.551] (II) DUMMYQBS(0): Output DUMMY15 has no monitor section
[ 18.551] (II) DUMMYQBS(0): Created crtc (0x56aaf85f9a10) and output DUMMY15 (0x56aaf85fa570)
[ 18.551] (II) DUMMYQBS(0): Printing probed modes for output DUMMY0
[ 18.551] (II) DUMMYQBS(0): Modeline "QB1920x1080"x46.1 96.00 1920 1921 1922 1923 1080 1081 1082 1083 (49.9 kHz UzP)
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY1
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY2
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY3
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY4
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY5
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY6
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY7
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY8
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY9
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY10
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY11
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY12
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY13
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY14
[ 18.551] (II) DUMMYQBS(0): EDID for output DUMMY15
[ 18.551] (II) DUMMYQBS(0): Output DUMMY0 connected
[ 18.551] (II) DUMMYQBS(0): Output DUMMY1 disconnected
[ 18.551] (II) DUMMYQBS(0): Output DUMMY2 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY3 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY4 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY5 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY6 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY7 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY8 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY9 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY10 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY11 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY12 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY13 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY14 disconnected
[ 18.552] (II) DUMMYQBS(0): Output DUMMY15 disconnected
[ 18.552] (II) DUMMYQBS(0): Using user preference for initial modes
[ 18.552] (II) DUMMYQBS(0): Output DUMMY0 using initial mode QB1920x1080 +0+0
[ 18.552] (II) DUMMYQBS(0): Using 0 scanlines of offscreen memory
[ 18.552] (==) DUMMYQBS(0): Backing store enabled
[ 18.552] (==) DUMMYQBS(0): Silken mouse enabled
[ 18.554] (II) Initializing extension Generic Event Extension
[ 18.554] (II) Initializing extension SHAPE
[ 18.554] (II) Initializing extension MIT-SHM
[ 18.554] (II) Initializing extension XInputExtension
[ 18.554] (II) Initializing extension XTEST
[ 18.554] (II) Initializing extension BIG-REQUESTS
[ 18.554] (II) Initializing extension SYNC
[ 18.554] (II) Initializing extension XKEYBOARD
[ 18.554] (II) Initializing extension XC-MISC
[ 18.555] (II) Initializing extension SECURITY
[ 18.555] (II) Initializing extension XFIXES
[ 18.555] (II) Initializing extension RENDER
[ 18.555] (II) Initializing extension RANDR
[ 18.555] (II) Initializing extension COMPOSITE
[ 18.555] (II) Initializing extension DAMAGE
[ 18.555] (II) Initializing extension MIT-SCREEN-SAVER
[ 18.555] (II) Initializing extension DOUBLE-BUFFER
[ 18.555] (II) Initializing extension RECORD
[ 18.556] (II) Initializing extension DPMS
[ 18.556] (II) Initializing extension Present
[ 18.556] (II) Initializing extension DRI3
[ 18.556] (II) Initializing extension X-Resource
[ 18.556] (II) Initializing extension XVideo
[ 18.557] (II) Initializing extension XVideo-MotionCompensation
[ 18.557] (II) Initializing extension SELinux
[ 18.557] (II) SELinux: Disabled on system
[ 18.557] (II) Initializing extension GLX
[ 18.557] (II) AIGLX: Screen 0 is not DRI2 capable
[ 18.855] (II) IGLX: Loaded and initialized swrast
[ 18.855] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 18.855] (II) Initializing extension XFree86-VidModeExtension
[ 18.855] (II) Initializing extension XFree86-DGA
[ 18.855] (II) Initializing extension DRI2
[ 18.855] (II) DUMMYQBS(0): Setting screen physical size to 508 x 285
[ 18.914] (II) Using input driver 'qubes' for 'qubesdev'
[ 18.914] (**) qubesdev: always reports core events
[ 18.914] (II) qubesdev: Using device /var/run/xf86-qubes-socket.
[ 18.914] (II) XINPUT: Adding extended input device "qubesdev" (type: MOUSE, id 6)
[ 18.914] (II) qubesdev: num_buttons=7
[ 18.914] (**) qubesdev: (accel) keeping acceleration scheme 1
[ 18.914] (**) qubesdev: (accel) acceleration profile 0
[ 18.914] (**) qubesdev: (accel) acceleration factor: 2.000
[ 18.914] (**) qubesdev: (accel) acceleration threshold: 4
[ 18.914] (II) qubesdev: On.
[ 18.937] (II) config/udev: Adding input device PC Speaker (/dev/input/event0)
[ 18.937] (II) No input driver specified, ignoring this device.
[ 18.937] (II) This device may have been added with another device file.
