After that you can’t just enable rpm-fusion like this:
sudo dnf config-manager --set-enabled rpmfusion-free
you need to manually add the gpg-keys etc…
Is this intended behavior?
I guess there is no package that provides the repo files for qubes?
To keep rpmfusion keys up to date, you need to have it enabled during upgrade. Otherwise it doesn’t have any place to fetch new keys from.
Okay that makes sense, the new repo files were also missing (had a weird file extension).
A short notice on the wiki would be nice.
