Importing GPG manually
I’m trying to do something like this in my template
curl -fSsL https://blablabla/FILENAME.GPG | sudo gpg --dearmor | sudo tee /usr/share/keyrings/thefile.gpg > /dev/null
But this way I get curl error of Could not resolve host
So… I googled half a day for this and couldn’t do much…
I tried to download that .gpg file in another qube and transfer it to the template, but I don’t really understand how I can manually import that .gpg file…
I use debian template and I have curl and apt-transport-https installed
Templates doesn’t have a direct access to the internet, you need to make curl use the local proxy http://127.0.0.1:8082/
OMFG! It worked…! THANK YOU!
BTW: if to do it manually… how should I do it? maybe you know? because I tried like thousand ways and it didn’t worked.
Maybe like this:
cat FILENAME.GPG | sudo gpg --dearmor | sudo tee /usr/share/keyrings/thefile.gpg > /dev/null
this should work
curl -x http://127.0.0.1:8082/ https://some_url
YES! the cat FILENAME.GPG worked too!
yo guys… you have no idea how much energy I spent on this and you helped like within 2 mins :smile:
THANK YOU!
Yeah… I did it the first time you said about proxy and it worked! Thank you!
ah, I may have not understood what you meant by “manually” :sweat_smile:
:smile:
This is also covered in the documentation:
