When Whonix gateway is updated using the Qubes updater, the sys-whonix qube is rebooted without any fuss, even when I have Whonix workstation qubes open.
However, when I try to reboot sys-whonix manually, Qubes tells me to close all my Whonix workstation qubes. That means closing all my work. A major PITA.
For context, I turn off networking now and then, and this causes sdwdate to get cranky. Rebooting sdwdate doesn’t always work, but rebooting sys-whonix does.
Any OGs know how to pull this off with a command I can bind to a key? Or anything?
Is there an obvious reason why this might be a really bad idea?
A workaround is to open a terminal in the qube, type systemctl reboot, the qube will stop (but not restart), then start the qube manually either from the menu or with qvm-start $qube_name, this will do the trick fine.
My initial thought was to suggest you to set network of workstation qubes to “none”, then reboot sys-whonix, then set it as workstations network-qube again.
But I just checked and my sys-whonix rebooted without any questions (I did this at Qube Manager), even though it was a networking qube for other qubes, which is quite unexpected behavior.
