I want to get more involved
I’d like to get involved more with QubesOS but don’t know how I can help or get more involved? I just installed Qubes4.0.4 onto a brand new Acer Aspire 5 with 10th gen i7 CPU. I noticed it wasn’t in the HCL but am unsure of how to submit a HCL too without compromising my privacy?
Thanks in advance.
rarez
If you are really worried about privacy, you already shared too much.
Username, Qubes OS revision & what machine you use.
You can create an HCL report on your machine and inspect the YML file
what information is shared. Don’t worry about the FIXME entires, I’ll
take care of them.
If you are OK with the level of information (e.g. there are no serial
numbers or similar, but BIOS version, installed memory etc) you can
submit the HCL to the forum.
Thank you for your reply @Sven I will do this later today.
Done @Sven , HCL - Acer Aspire 515-55 - Intel core i7 10th Gen
Thank you @rarez. See here how you can help:
